소개
In this guide you will learn how to replace the speakers in an Asus EeeBook X205TA.
필요한 것
Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
Locate and lift the tabs from the LED/motherboard ribbon cable.
Remove the cable.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Thanks. You’ve helped make it clearer for me!
