주요 콘텐츠로 건너뛰기
Asus EeeBook X205TA Speakers Replacement
필요한 것
  1. Asus EeeBook X205TA Speakers Replacement, Battery: 1 단계, 이미지 2개 중 1개 Asus EeeBook X205TA Speakers Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Speakers Replacement: 3 단계, 이미지 2개 중 1개 Asus EeeBook X205TA Speakers Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Speakers Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Speakers Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully lift the battery out of the laptop.
  6. Asus EeeBook X205TA Speakers Replacement, Speakers: 6 단계, 이미지 1개 중 1개
    • Locate and lift the tabs from the LED/motherboard ribbon cable.
    • Remove the cable.
  7. Asus EeeBook X205TA Speakers Replacement: 7 단계, 이미지 1개 중 1개
    • Unplug the speaker cable from the motherboard.
  8. Asus EeeBook X205TA Speakers Replacement: 8 단계, 이미지 1개 중 1개
    • Pry the right speaker gently with the plastic opening tool.
  9. Asus EeeBook X205TA Speakers Replacement: 9 단계, 이미지 1개 중 1개
    • Pry the left speaker gently with the plastic opening tool.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
William Riggins
회원 가입일: 03/21/17
319 평판
안내서 2개를 작성함
IUPUI, Team S3-G4, Baechle Spring 2017 IUPUI, Team S3-G4, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S3G4
4 회원들
안내서 6개를 작성함
댓글 2개
Thank you very much for this detailed and helpful tutorial.
andrew - 답글
Thanks. You’ve helped make it clearer for me!
geometry dash
Martin Tolley - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 5
전체 시간: 939
