주요 콘텐츠로 건너뛰기
Asus F554LA-WS52 Disc Drive
필요한 것
  1. Asus F554LA-WS52 Disc Drive, Disc Drive: 1 단계, 이미지 1/2 Asus F554LA-WS52 Disc Drive, Disc Drive: 1 단계, 이미지 2/2
    • Make sure the notebook is off and has been unplugged from any power source.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Disc Drive: 2 단계, 이미지 1/3 Asus F554LA-WS52 Disc Drive: 2 단계, 이미지 2/3 Asus F554LA-WS52 Disc Drive: 2 단계, 이미지 3/3
    • With a plastic opening tool, gently lift and remove the back cover to expose the internal components.
    • (Not pictured) Remove the three cables attached to the keyboard and one touch-pad.
  3. Asus F554LA-WS52 Disc Drive: 3 단계, 이미지 1/2 Asus F554LA-WS52 Disc Drive: 3 단계, 이미지 2/2
    • Unscrew the three 5.7 mm hard drive-motherboard connection screws with a #0 Phillips head screwdriver.
    • Remove the small rectangular hard drive-motherboard connection board.
    • (Not pictured) Remove the hard drive.
  4. Asus F554LA-WS52 Disc Drive: 4 단계, 이미지 1/2 Asus F554LA-WS52 Disc Drive: 4 단계, 이미지 2/2
    • Unscrew the four 5.7 mm battery screws with a #0 Phillips head screwdriver.
    • Remove the battery.
  5. Asus F554LA-WS52 Disc Drive: 5 단계, 이미지 1/3 Asus F554LA-WS52 Disc Drive: 5 단계, 이미지 2/3 Asus F554LA-WS52 Disc Drive: 5 단계, 이미지 3/3
    • Unscrew the two 2.7 mm and one 5.7 mm CD drive screws with the Phillips #00 screwdriver.
    • With the plastic opening tool, gently pry the drive out from the metal brackets that hold it in place.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Aaron Ratliff
회원 가입일: 10/09/18
527 평판
안내서 4개 작성하였습니다
USF Tampa, Team S1-G2, Leahy Fall 2018 USF Tampa, Team S1-G2, Leahy Fall 2018 회원
USFT-LEAHY-F18S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 550
