소개
Many of the Asus F554LA-WS52 notebook's components take several steps to remove and replace. This sequential guide shows the necessary steps. For this guide, you will need a plastic opening tool and a Phillips #00 screwdriver head.
필요한 것
Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
Recommend that you line up your screws in order of removal, so that you know which hole they go in - there are multiple size screws. This will save you trouble trying to fit the right screw to the right hole.
gabryant6 - 답글
