주요 콘텐츠로 건너뛰기
Asus F554LA-WS52 Screen Replacement
필요한 것
  1. Asus F554LA-WS52 Screen Replacement, Screen: 1 단계, 이미지 1/2 Asus F554LA-WS52 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Remove the two plastic screw coverings from the bottom of the screen panel.
  2. Asus F554LA-WS52 Screen Replacement: 2 단계, 이미지 1/2 Asus F554LA-WS52 Screen Replacement: 2 단계, 이미지 2/2
    • Remove the two 4.6mm screws using the Phillips #0 screwdriver.
  3. Asus F554LA-WS52 Screen Replacement: 3 단계, 이미지 1/2 Asus F554LA-WS52 Screen Replacement: 3 단계, 이미지 2/2
    • Using the plastic opening tool, gently pry the notebook's plastic screen covering away from the screen.
  4. Asus F554LA-WS52 Screen Replacement: 4 단계, 이미지 1/2 Asus F554LA-WS52 Screen Replacement: 4 단계, 이미지 2/2
    • Remove the two 4.6mm screws holding screen in place.
  5. Asus F554LA-WS52 Screen Replacement: 5 단계, 이미지 1/3 Asus F554LA-WS52 Screen Replacement: 5 단계, 이미지 2/3 Asus F554LA-WS52 Screen Replacement: 5 단계, 이미지 3/3
    • Carefully, lay screen down on the keyboard.
    • Be cautious as the screen will still be attached.
  6. Asus F554LA-WS52 Screen Replacement: 6 단계, 이미지 1/3 Asus F554LA-WS52 Screen Replacement: 6 단계, 이미지 2/3 Asus F554LA-WS52 Screen Replacement: 6 단계, 이미지 3/3
    • Remove tape that covers the visual pin connectors.
    • Gently disconnect the screen from the pin connectors and replace.
결론
Aaron Ratliff
회원 가입일: 10/09/18
527 평판
안내서 4개 작성하였습니다
USF Tampa, Team S1-G2, Leahy Fall 2018 USF Tampa, Team S1-G2, Leahy Fall 2018 회원
USFT-LEAHY-F18S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 361
