주요 콘텐츠로 건너뛰기
Asus F554LA-WS52 Speakers Replacement
필요한 것
  1. Asus F554LA-WS52 Speakers Replacement, Speakers: 1 단계, 이미지 1/2 Asus F554LA-WS52 Speakers Replacement, Speakers: 1 단계, 이미지 2/2
    • Using the plastic opening tool, gently pry open the keyboard.
    • Once the keyboard is up, gently remove it.
  2. Asus F554LA-WS52 Speakers Replacement: 2 단계, 이미지 1/2 Asus F554LA-WS52 Speakers Replacement: 2 단계, 이미지 2/2
    • Speakers are located on the bottom left hand side of the device.
  3. Asus F554LA-WS52 Speakers Replacement: 3 단계, 이미지 1/2 Asus F554LA-WS52 Speakers Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool to release the speaker from its position.
  4. Asus F554LA-WS52 Speakers Replacement: 4 단계, 이미지 1/2 Asus F554LA-WS52 Speakers Replacement: 4 단계, 이미지 2/2
    • After the speaker is completely out, gently remove the wire that is attached to the speaker.
결론
Matthew Belz
회원 가입일: 10/09/18
115 평판
안내서 1개 작성함
USF Tampa, Team S1-G2, Leahy Fall 2018 USF Tampa, Team S1-G2, Leahy Fall 2018 회원
USFT-LEAHY-F18S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 18
전체 시간: 1,151
