주요 콘텐츠로 건너뛰기
Asus F554LA-WS52 Touchpad Replacement
필요한 것
  1. Asus F554LA-WS52 Touchpad Replacement, Touchpad: 1 단계, 이미지 1/3 Asus F554LA-WS52 Touchpad Replacement, Touchpad: 1 단계, 이미지 2/3 Asus F554LA-WS52 Touchpad Replacement, Touchpad: 1 단계, 이미지 3/3
    • Make sure your notebook device is unplugged and turned off before opening it up.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Touchpad Replacement: 2 단계, 이미지 1/3 Asus F554LA-WS52 Touchpad Replacement: 2 단계, 이미지 2/3 Asus F554LA-WS52 Touchpad Replacement: 2 단계, 이미지 3/3
    • Once the screws are removed, carefully lift both sides of the plastic keyboard/touch pad cover with a plastic opening tool.
  3. Asus F554LA-WS52 Touchpad Replacement: 3 단계, 이미지 1/1
    • Lift the plastic cover and unplug the three data cords (not all pictured) under the cover from the keyboard and motherboard.
  4. Asus F554LA-WS52 Touchpad Replacement: 4 단계, 이미지 1/3 Asus F554LA-WS52 Touchpad Replacement: 4 단계, 이미지 2/3 Asus F554LA-WS52 Touchpad Replacement: 4 단계, 이미지 3/3
    • Once you've removed the plastic cover, flip it over.
    • Next, carefully remove the tape from the bottom side of your touch pad.
  5. Asus F554LA-WS52 Touchpad Replacement: 5 단계, 이미지 1/1
    • Locate and unscrew the three 3.2 mm at the top edge of the touch pad using the Phillips #0 screwdriver.
  6. Asus F554LA-WS52 Touchpad Replacement: 6 단계, 이미지 1/3 Asus F554LA-WS52 Touchpad Replacement: 6 단계, 이미지 2/3 Asus F554LA-WS52 Touchpad Replacement: 6 단계, 이미지 3/3
    • Gently push the front of the touch pad with your finger to remove it from its position within the keyboard.
    • Replace touch pad.
결론
Clint Eagle
회원 가입일: 10/09/18
300 평판
안내서 1개 작성함
USF Tampa, Team S1-G2, Leahy Fall 2018 USF Tampa, Team S1-G2, Leahy Fall 2018 회원
USFT-LEAHY-F18S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 215
