이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
Once the screws are removed, carefully lift both sides of the plastic keyboard/touch pad cover with a plastic opening tool.
Lift the plastic cover and unplug the three data cords (not all pictured) under the cover from the keyboard and motherboard.
Once you've removed the plastic cover, flip it over.
Next, carefully remove the tape from the bottom side of your touch pad.
Locate and unscrew the three 3.2 mm at the top edge of the touch pad using the Phillips #0 screwdriver.
Gently push the front of the touch pad with your finger to remove it from its position within the keyboard.
Replace touch pad.
