주요 콘텐츠로 건너뛰기
Asus F555LA-AB31 CD Drive Replacement
필요한 것
  1. Asus F555LA-AB31 CD Drive Replacement, CD Drive: 1 단계, 이미지 1/1
    • Turn off and unplug the device before starting repairing.
    • Use the Phillips #0 screwdriver head to remove the ten 18mm Phillips #0 screws on the laptop's bottom.
  2. Asus F555LA-AB31 CD Drive Replacement: 2 단계, 이미지 1/2 Asus F555LA-AB31 CD Drive Replacement: 2 단계, 이미지 2/2
    • Flip the laptop over and flip the screen up.
    • Pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
  3. Asus F555LA-AB31 CD Drive Replacement: 3 단계, 이미지 1/1
    • Disconnect the keyboard flex cable from its motherboard ZIF socket.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
  4. Asus F555LA-AB31 CD Drive Replacement: 4 단계, 이미지 1/2 Asus F555LA-AB31 CD Drive Replacement: 4 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to unscrew the one Phillips #0 screw that connects the CD drive to the motherboard.
    • Slowly slide out the CD drive, keeping it level, to remove it.
결론
Darren Early
회원 가입일: 04/04/19
97 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 14
전체 시간: 388
