주요 콘텐츠로 건너뛰기
Asus F555LA-AB31 Fan Replacement
필요한 것
  1. Asus F555LA-AB31 Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Remove ten 18mm Phillips #0 screws from the backside of the device.
    • Removal of the RAM access panel is not necessary.
  2. Asus F555LA-AB31 Fan Replacement: 2 단계, 이미지 1/3 Asus F555LA-AB31 Fan Replacement: 2 단계, 이미지 2/3 Asus F555LA-AB31 Fan Replacement: 2 단계, 이미지 3/3
    • Open the laptop.
    • Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
    • To remove the ZIF connector, gently lift upward on the blue tab to disconnect it from the motherboard.
  3. Asus F555LA-AB31 Fan Replacement: 3 단계, 이미지 1/1
    • Fold the faceplate upwards towards the screen to fully expose the inside of the laptop.
    • Both the battery and the hard drive adapter PCB will need to be moved in order to lift and access the backside of the motherboard.
    • Unscrew the eight Phillips #0 screws on from the battery, and four Phillips #0 screws from the hard drive adapter PCB.
  4. Asus F555LA-AB31 Fan Replacement: 4 단계, 이미지 1/3 Asus F555LA-AB31 Fan Replacement: 4 단계, 이미지 2/3 Asus F555LA-AB31 Fan Replacement: 4 단계, 이미지 3/3
    • Remove the CD drive by unscrewing the single 4mm Phillips #0 screw and sliding the drive away from the motherboard.
    • Disconnect the two antennas that are attached to the network card.
  5. Asus F555LA-AB31 Fan Replacement: 5 단계, 이미지 1/2 Asus F555LA-AB31 Fan Replacement: 5 단계, 이미지 2/2
    • Remove the seven 4mm Phillips #0 screws holding the motherboard down to the laptop chassis.
    • Lift the motherboard upwards, folding it towards the laptop screen.
    • The motherboard will still be attached by two wires, but it is unnecessary to remove these wires to access the fan.
    • Disconnect the 4-pin PWM cable attaching the fan to the back of the motherboard. The fan can now be removed by simply sliding the fan off the copper heat pipe.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jordan Renteria
회원 가입일: 04/04/19
356 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 15
전체 시간: 946
