주요 콘텐츠로 건너뛰기
Asus F555LA-AB31 Hard Drive Replacement
필요한 것
  1. Asus F555LA-AB31 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Remove ten 18mm Phillips #0 screws from the backside of the device.
    • Removal of the RAM access panel is not necessary.
  2. Asus F555LA-AB31 Hard Drive Replacement: 2 단계, 이미지 1/3 Asus F555LA-AB31 Hard Drive Replacement: 2 단계, 이미지 2/3 Asus F555LA-AB31 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Carefully fold the device open.
    • Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
    • To remove the ZIF connector, gently lift upward on the blue tab to disconnect it from the motherboard.
  3. Asus F555LA-AB31 Hard Drive Replacement: 3 단계, 이미지 1/3 Asus F555LA-AB31 Hard Drive Replacement: 3 단계, 이미지 2/3 Asus F555LA-AB31 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Fold the keyboard section of the laptop up towards the screen to fully expose the inside of the device.
    • Unscrew the four 4mm Phillips #0 screws holding down the hard drive.
  4. Asus F555LA-AB31 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Disconnect the ZIF connector and lift the hard drive out of the space.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
JC Chavez
회원 가입일: 04/04/19
202 평판
안내서 2개 작성하였습니다
댓글 한 개
Boo, 10 screws in first step are not all the same length, 4 screws in third step are not correctly indicated in the image (nor are they all in view in said image). Finally, there’s a hard drive bracket that is not included in the guide which is important to note how it is positioned to reinstall correctly.
Jeb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 40
전체 시간: 1,865
