주요 콘텐츠로 건너뛰기
Asus F555LA-AB31 RAM Replacement
필요한 것
  1. Asus F555LA-AB31 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Remove the Phillips #0 screw holding the RAM access panel in place.
    • Gently lift up on the edge of the panel to remove it.
  2. Asus F555LA-AB31 RAM Replacement: 2 단계, 이미지 1/1
    • With the panel removed, The single upgradable RAM slot is easily accessible.
    • If RAM is already installed, it can be removed by gently pulling the retainers sideways away from the RAM to release it.
    • To install RAM, slide the DIMM into the socket at an angle of approximately 20 degrees from flat. Make sure the notch in the RAM module aligns with the notch in the socket. Gently push down on the RAM module until the retainers click into place.
결론
To reassemble your device, reinstall the access panel by following these instructions in reverse order.
Jordan Renteria
회원 가입일: 04/04/19
356 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 27
전체 시간: 885
