주요 콘텐츠로 건너뛰기
Asus F6A-X2 Battery Replacement
  1. Asus F6A-X2 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
    • Flip laptop face down and rotate so the battery is facing toward you.
    • The battery is not shown in this picture.
    • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
    • Slide the battery toward you and lift it out of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jonathan
회원 가입일: 04/24/14
1,174 평판
안내서 11개 작성하였습니다
Cal Poly, Team 10-56, Amido Spring 2014 Cal Poly, Team 10-56, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G56
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 741
