주요 콘텐츠로 건너뛰기
Asus F6A-X2 Bottom Access Panel Replacement
필요한 것
  1. Asus F6A-X2 Bottom Access Panel Replacement, Back Access Panel: 1 단계, 이미지 1/2 Asus F6A-X2 Bottom Access Panel Replacement, Back Access Panel: 1 단계, 이미지 2/2
    • With the laptop facing down, rotate it so the battery pack is facing away from you.
    • Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
  2. Asus F6A-X2 Bottom Access Panel Replacement: 2 단계, 이미지 1/3 Asus F6A-X2 Bottom Access Panel Replacement: 2 단계, 이미지 2/3 Asus F6A-X2 Bottom Access Panel Replacement: 2 단계, 이미지 3/3
    • Insert a finger into one of the slots on the bottom panel.
    • Gently lift the upwards, and the back panel of the laptop will come off easily.
결론
Mikel Sangroniz
회원 가입일: 04/25/14
192 평판
안내서 1개 작성함
Cal Poly, Team 10-56, Amido Spring 2014 Cal Poly, Team 10-56, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G56
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 976
