주요 콘텐츠로 건너뛰기
Asus F6A-X2 Front Bezel Replacement
필요한 것
  1. Asus F6A-X2 Front Bezel Replacement, Front Bezel: 1 단계, 이미지 2개 중 1개 Asus F6A-X2 Front Bezel Replacement, Front Bezel: 1 단계, 이미지 2개 중 2개
    • Lay the laptop right side up.
    • Rotate laptop 90 degrees towards you, so the empty battery compartment is visible.
  2. Asus F6A-X2 Front Bezel Replacement: 2 단계, 이미지 2개 중 1개 Asus F6A-X2 Front Bezel Replacement: 2 단계, 이미지 2개 중 2개
    • Insert a finger nail, or the flat end of the spudger, into the slot between the laptop base and the hinge guard on the right side. Gently pull the guard towards you until the guard pops off.
    • Repeat this process for the other guard.
  3. Asus F6A-X2 Front Bezel Replacement: 3 단계, 이미지 2개 중 1개 Asus F6A-X2 Front Bezel Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Once the hinge guards are removed, lay the laptop flat on its bottom. Then, lift open the laptop screen as if you were about to use it.
    • With a pair of tweezers, peel off the six rubber cushions from the bezel located around the perimeter of the screen.
  4. Asus F6A-X2 Front Bezel Replacement: 4 단계, 이미지 2개 중 1개 Asus F6A-X2 Front Bezel Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the six 2.0 mm Phillips #1 screws from the perimeter of the bezel.
  5. Asus F6A-X2 Front Bezel Replacement: 5 단계, 이미지 2개 중 1개 Asus F6A-X2 Front Bezel Replacement: 5 단계, 이미지 2개 중 2개
    • Insert a finger nail, or the flat end of a spudger, into the slit between the bezel and the back cover of the laptop.
    • Gently pry the bezel towards you to remove it from the back panel of the laptop.
    • Hearing a cracking noise is normal. The bezel is not damaged in this process.
    • Continue to pry around the perimeter of the laptop until the entire bezel has been removed.
결론
작성자
5다른 기여자 명과 함께
Jonathan
회원 가입일: 04/24/14
1,174 평판
안내서 11개를 작성함
Cal Poly, Team 10-56, Amido Spring 2014 Cal Poly, Team 10-56, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G56
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 640
