주요 콘텐츠로 건너뛰기
Asus F6A-X2 RAM Replacement
필요한 것
  1. Asus F6A-X2 RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
    • Flip laptop face down and rotate so the battery is facing toward you.
    • The battery is not shown in this picture.
    • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
    • Slide the battery toward you and lift it out of the laptop.
  2. Asus F6A-X2 RAM Replacement, Back Access Panel: 2 단계, 이미지 2개 중 1개 Asus F6A-X2 RAM Replacement, Back Access Panel: 2 단계, 이미지 2개 중 2개
    • With the laptop facing down, rotate it so the battery pack is facing away from you.
    • Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
  3. Asus F6A-X2 RAM Replacement: 3 단계, 이미지 3개 중 1개 Asus F6A-X2 RAM Replacement: 3 단계, 이미지 3개 중 2개 Asus F6A-X2 RAM Replacement: 3 단계, 이미지 3개 중 3개
    • Insert a finger into one of the slots on the bottom panel.
    • Gently lift the upwards, and the back panel of the laptop will come off easily.
  4. Asus F6A-X2 RAM Replacement, RAM: 4 단계, 이미지 2개 중 1개 Asus F6A-X2 RAM Replacement, RAM: 4 단계, 이미지 2개 중 2개
    • Make sure to check the RAM specifications on the device page.
    • There are two white plastic tabs holding the RAM in place. Place two fingers on each of these tabs, and pull outward.
    • You will hear a pop and visibly see the RAM move upwards.
    • Slide the RAM towards the back end of the laptop (the end with the battery), and lift up to remove it.
  5. Asus F6A-X2 RAM Replacement: 5 단계, 이미지 2개 중 1개 Asus F6A-X2 RAM Replacement: 5 단계, 이미지 2개 중 2개
    • Repeat the process from the previous step to remove the bottom RAM.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jonathan
회원 가입일: 04/24/14
1,174 평판
안내서 11개를 작성함
Cal Poly, Team 10-56, Amido Spring 2014 Cal Poly, Team 10-56, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G56
4 회원들
안내서 12개를 작성함
1가이드 댓글
Tutorel simple et très clair.
Merci
alainbadinier - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 642
