주요 콘텐츠로 건너뛰기
Asus G501JW-BHI7N12 Cooling Fan Replacement
필요한 것
  1. Asus G501JW-BHI7N12 Cooling Fan Replacement, Cooling Fan: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
  2. Asus G501JW-BHI7N12 Cooling Fan Replacement: 2 단계, 이미지 1/1
    • Unscrew and remove the four 5mm Phillips #0 screws from the cooling fan.
  3. Asus G501JW-BHI7N12 Cooling Fan Replacement: 3 단계, 이미지 1/1
    • Remove 4 pin connector from mother board.
  4. Asus G501JW-BHI7N12 Cooling Fan Replacement: 4 단계, 이미지 1/1
    • Slide cooling fan out from underneath the copper heat sink.
    • The cooling fan will be clipped to the case, we suggest pulling it toward the front of the case. Using the spudger can be helpful to work the fan loose.
  5. Asus G501JW-BHI7N12 Cooling Fan Replacement: 5 단계, 이미지 1/1
    • One of the fans will have a connector that partially covers it. Pull the connector loose by flipping up the plastic clamps on both ends and follow steps 2-4.
결론
Dustin Annis
회원 가입일: 02/08/17
214 평판
안내서 2개 작성하였습니다
UW Tacoma, Team 2-1, Rose Winter 2017 UW Tacoma, Team 2-1, Rose Winter 2017 회원
UWT-ROSE-W17S2G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 17
전체 시간: 2,071
