소개
Replacing the motherboard on the Asus G501JW-BHI7N12 is essential. Without the motherboard, you have no computer. Although removing the motherboard looks scary, following these steps will allow you to smoothly and carefully remove the motherboard without damaging any other part of the computer.
필요한 것
Remove the four 7.0mm Philips #0 screws around the battery.
Attach an anti static wrist strap to your hand and clip to the laptop case.
Using the Phillips #0 screwdriver, remove the six 5 mm screws located along the copper heat sink.
