주요 콘텐츠로 건너뛰기
Asus G55VW DS71 Disk Drive Replacement
필요한 것
  1. Asus G55VW DS71 Disk Drive Replacement, Battery: 1 단계, 이미지 1/2 Asus G55VW DS71 Disk Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the computer is off and turn it over on its back. Push the slider all the way back until the compartment for the battery opens. Remove the battery and place it aside.
  2. Asus G55VW DS71 Disk Drive Replacement, Keyboard: 2 단계, 이미지 1/2 Asus G55VW DS71 Disk Drive Replacement, Keyboard: 2 단계, 이미지 2/2
    • Find the panel on the back of the computer. Use a Phillips #0 screwdriver to unscrew the 2 4.2mm screws on that panel. Next, lift up the panel at the indent and place it aside.
  3. Asus G55VW DS71 Disk Drive Replacement: 3 단계, 이미지 1/1
    • When the back panel is removed, disconnect the blue and black ribbon connectors exposed from the back panel.
  4. Asus G55VW DS71 Disk Drive Replacement: 4 단계, 이미지 1/1
    • Remove the fifteen 4.2 mm screws on the bottom of the laptop with a Phillips #0 screwdriver, under the battery, and beneath the back panel that secure the keyboard to the laptop.
    • The top-left and upper center screws are difficult to reach with the iFixit screw kit.
  5. Asus G55VW DS71 Disk Drive Replacement: 5 단계, 이미지 1/2 Asus G55VW DS71 Disk Drive Replacement: 5 단계, 이미지 2/2
    • Begin to pry the keyboard off of the laptop with the pointed metal spudger.
    • It is possible to damage yourself as well as the device with the metal spudgers. Exercise extreme caution.
  6. Asus G55VW DS71 Disk Drive Replacement: 6 단계, 이미지 1/3 Asus G55VW DS71 Disk Drive Replacement: 6 단계, 이미지 2/3 Asus G55VW DS71 Disk Drive Replacement: 6 단계, 이미지 3/3
    • Remove the ribbon connectors that connect the keyboard to the motherboard. The keyboard should now be completely disconnected from the laptop.
  7. Asus G55VW DS71 Disk Drive Replacement, Disk Drive: 7 단계, 이미지 1/1
    • Placing your hand on the side of the disk drive closest to the motherboard, slightly push down and out to remove the drive.
결론
Andres Santiesteban
회원 가입일: 09/26/18
375 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 270
