필요한 것
Make sure the computer is off and turn it over on its back. Push the slider all the way back until the compartment for the battery opens. Remove the battery and place it aside.
Find the panel on the back of the computer. Use a Phillips #0 screwdriver to unscrew the 2 4.2mm screws on that panel. Next, lift up the panel at the indent and place it aside.
Placing your hand on the side of the disk drive closest to the motherboard, slightly push down and out to remove the drive.
거의 끝나갑니다!
결론
