이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Make sure the computer is off and turn it over on its back. Push the slider all the way back until the compartment for the battery opens. Remove the battery and place it aside.
Find the panel on the back of the computer. Using a Phillips #0 screwdriver, unscrew the 2 4.2mm screws on that panel. Lift up the panel at the indent and place it aside.
다른 한 분이 해당 안내서를 완성하였습니다.
