주요 콘텐츠로 건너뛰기
Asus G55VW DS71 Sound Bar Replacement
필요한 것
  1. Asus G55VW DS71 Sound Bar Replacement, Battery: 1 단계, 이미지 1/2 Asus G55VW DS71 Sound Bar Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the computer is off and turn it over on its back. Push the slider all the way back until the compartment for the battery opens. Remove the battery and place it aside.
  2. Asus G55VW DS71 Sound Bar Replacement, Keyboard: 2 단계, 이미지 1/2 Asus G55VW DS71 Sound Bar Replacement, Keyboard: 2 단계, 이미지 2/2
    • Find the panel on the back of the computer. Use a Phillips #0 screwdriver to unscrew the 2 4.2mm screws on that panel. Next, lift up the panel at the indent and place it aside.
  3. Asus G55VW DS71 Sound Bar Replacement: 3 단계, 이미지 1/1
    • When the back panel is removed, disconnect the blue and black ribbon connectors exposed from the back panel.
  4. Asus G55VW DS71 Sound Bar Replacement: 4 단계, 이미지 1/1
    • Remove the fifteen 4.2 mm screws on the bottom of the laptop with a Phillips #0 screwdriver, under the battery, and beneath the back panel that secure the keyboard to the laptop.
    • The top-left and upper center screws are difficult to reach with the iFixit screw kit.
  5. Asus G55VW DS71 Sound Bar Replacement: 5 단계, 이미지 1/2 Asus G55VW DS71 Sound Bar Replacement: 5 단계, 이미지 2/2
    • Begin to pry the keyboard off of the laptop with the pointed metal spudger.
    • It is possible to damage yourself as well as the device with the metal spudgers. Exercise extreme caution.
  6. Asus G55VW DS71 Sound Bar Replacement: 6 단계, 이미지 1/3 Asus G55VW DS71 Sound Bar Replacement: 6 단계, 이미지 2/3 Asus G55VW DS71 Sound Bar Replacement: 6 단계, 이미지 3/3
    • Remove the ribbon connectors that connect the keyboard to the motherboard. The keyboard should now be completely disconnected from the laptop.
  7. Asus G55VW DS71 Sound Bar Replacement, Sound Bar: 7 단계, 이미지 1/2 Asus G55VW DS71 Sound Bar Replacement, Sound Bar: 7 단계, 이미지 2/2
    • Remove the panel by popping it off.
  8. Asus G55VW DS71 Sound Bar Replacement: 8 단계, 이미지 1/2 Asus G55VW DS71 Sound Bar Replacement: 8 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to unscrew 3 screws on the audio board.
  9. Asus G55VW DS71 Sound Bar Replacement: 9 단계, 이미지 1/1
    • Lift the audio board and find the 2 wires connecting it to the computer.
    • Pull on those wires to disconnect them .
결론
Blake Cangolosi
회원 가입일: 09/26/18
178 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 254
