주요 콘텐츠로 건너뛰기
Asus G73JH-RBBX05 Fan Replacement
필요한 것
  1. Asus G73JH-RBBX05 Fan Replacement, Keyboard: 1 단계, 이미지 1/2 Asus G73JH-RBBX05 Fan Replacement, Keyboard: 1 단계, 이미지 2/2
    • Locate the 5 clips located at the top of the keyboard. Insert a metal spudger into the clip openings on the keyboard to remove the keyboard.
  2. Asus G73JH-RBBX05 Fan Replacement: 2 단계, 이미지 1/3 Asus G73JH-RBBX05 Fan Replacement: 2 단계, 이미지 2/3 Asus G73JH-RBBX05 Fan Replacement: 2 단계, 이미지 3/3
    • Before fully removing the keyboard, remove the back lighting cable and keyboard data strip.
    • In order to remove these cables, push forward the black retention clips and pull out the cables.
  3. Asus G73JH-RBBX05 Fan Replacement, Fan: 3 단계, 이미지 1/1
    • Remove the 4mm screws located under the keyboard with the PH0 screwdriver.
  4. Asus G73JH-RBBX05 Fan Replacement: 4 단계, 이미지 1/2 Asus G73JH-RBBX05 Fan Replacement: 4 단계, 이미지 2/2
    • Using a PH0 screwdriver, remove the two, 4mm screws .
    • Using either your finger or a plastic opening tool, remove the back panel.
  5. Asus G73JH-RBBX05 Fan Replacement: 5 단계, 이미지 1/1
    • Using the PH0 screwdriver, remove the nine, 4mm screws on the bottom of the laptop.
    • You must remove the two, 4mm screws located under the battery. Remove the battery by following these steps: Asus G73JH-RBBX05 Battery Replacement
  6. Asus G73JH-RBBX05 Fan Replacement: 6 단계, 이미지 1/1
    • Using a metal spudger, remove the back cover of the laptop.
    • Apply constant force in order to unhinged the panel.
  7. Asus G73JH-RBBX05 Fan Replacement: 7 단계, 이미지 1/2 Asus G73JH-RBBX05 Fan Replacement: 7 단계, 이미지 2/2
    • Remove the four, 4mm screws located on both of the hinges using the PH0 screwdriver and flip open the device.
    • Make sure you do this step for both the left and right hinges.
  8. Asus G73JH-RBBX05 Fan Replacement: 8 단계, 이미지 1/2 Asus G73JH-RBBX05 Fan Replacement: 8 단계, 이미지 2/2
    • Using a metal pry tool, remove the base cover
    • Once the cover is completely unhinged, don't forget to detach the strips connected to the motherboard.
  9. Asus G73JH-RBBX05 Fan Replacement: 9 단계, 이미지 1/3 Asus G73JH-RBBX05 Fan Replacement: 9 단계, 이미지 2/3 Asus G73JH-RBBX05 Fan Replacement: 9 단계, 이미지 3/3
    • Locate the fan and remove the three 2mm screws with the PH0 screwdriver.
    • Before removing the fan, disconnect the cable.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Trevor Sprosty
회원 가입일: 01/23/17
409 평판
안내서 3개 작성하였습니다
Cal Poly, Team 22-11, Maness Winter 2017 Cal Poly, Team 22-11, Maness Winter 2017 회원
CPSU-MANESS-W17S22G11
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Some steps missing, regarding screws to remove: 1 screw that holds optical drive; once that is removed, 2 screws in the drive compartment; 2 screws in the battery compartment; 3 screws from the bottom of the motherboard.
Byron Canfield - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 1,627
