소개
Use this guide to remove and replace the RAM on the Asus G73JH-RBBX05.
필요한 것
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Unfortunately, not very helpful when the only one that needs replacing is the only one not noted in this guide. Under the inside of the board, right behind the third RAM stick, there is a fourth that requires almost a total disassembly of the unit to access.
nekospacer - 답글
