주요 콘텐츠로 건너뛰기
Asus G73JW-XT1 Optical Drive Replacement
필요한 것
  1. Asus G73JW-XT1  Optical Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the device over so the battery port is easy to access.
  2. Asus G73JW-XT1  Optical Drive Replacement: 2 단계, 이미지 1/2 Asus G73JW-XT1  Optical Drive Replacement: 2 단계, 이미지 2/2
    • Slide the left slider to the left so that it locks in place.
    • Slide the right slider to the right while pushing the battery away from you. The battery should disconnect.
  3. Asus G73JW-XT1  Optical Drive Replacement, Optical Drive: 3 단계, 이미지 1/2 Asus G73JW-XT1  Optical Drive Replacement, Optical Drive: 3 단계, 이미지 2/2
    • Turn the device off and remove any power cords. Dissassembling the device while it is under power may result in electric shock and potential damage to the device.
    • Rotate the device so the battery port is facing away.
    • Remove two 5.5 mm Phillips #0 screws on the back panel.
  4. Asus G73JW-XT1  Optical Drive Replacement: 4 단계, 이미지 1/3 Asus G73JW-XT1  Optical Drive Replacement: 4 단계, 이미지 2/3 Asus G73JW-XT1  Optical Drive Replacement: 4 단계, 이미지 3/3
    • Insert the opener tool into the small groove at the edge of the panel.
    • Using opener tool, gently pry the back panel upward until it lifts free from the device.
    • Gently lift the panel off with your fingers.
  5. Asus G73JW-XT1  Optical Drive Replacement: 5 단계, 이미지 1/1
    • Remove one 5.5 mm Phillips #0 screw directly to the right of the RAM cards.
  6. Asus G73JW-XT1  Optical Drive Replacement: 6 단계, 이미지 1/2 Asus G73JW-XT1  Optical Drive Replacement: 6 단계, 이미지 2/2
    • Insert the plastic opening tool in the gap between the motherboard and the back panel, directly to the right of the RAM cards.
    • Gently push the optical drive outwards. This should require very little pressure.
    • Grab the loose optical drive with your fingers and pull it free.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Emma Plass
회원 가입일: 09/27/18
406 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 326
