소개
Is your optical drive no longer reading discs? If so, here is the guide to fix the problem by simply removing the disc, buying a new one and installing it. All you need is the standard Phillips #0 screwdriver in order to remove the screws and plastic opening tools to remove covers.
필요한 것
Turn the device off and remove any power cords. Dissassembling the device while it is under power may result in electric shock and potential damage to the device.
Rotate the device so the battery port is facing away.
Remove two 5.5 mm Phillips #0 screws on the back panel.
다른 한 분이 해당 안내서를 완성하였습니다.
