주요 콘텐츠로 건너뛰기
Asus G73JW-XT1 Hard Drive Replacement
필요한 것
  1. Asus G73JW-XT1 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the device over so the battery port is easy to access.
  2. Asus G73JW-XT1 Hard Drive Replacement: 2 단계, 이미지 1/2 Asus G73JW-XT1 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Slide the left slider to the left so that it locks in place.
    • Slide the right slider to the right while pushing the battery away from you. The battery should disconnect.
  3. Asus G73JW-XT1 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/3 Asus G73JW-XT1 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/3 Asus G73JW-XT1 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3/3
    • Remove the two 5.5 mm Phillips #0 screws from the back cover.
    • Gently lift and remove the back cover.
  4. Asus G73JW-XT1 Hard Drive Replacement: 4 단계, 이미지 1/3 Asus G73JW-XT1 Hard Drive Replacement: 4 단계, 이미지 2/3 Asus G73JW-XT1 Hard Drive Replacement: 4 단계, 이미지 3/3
    • Remove the four 5.5 mm Phillips #0 screws.
    • Gently lift the hard drive starting on the far side.
결론
Nathan T Endner
회원 가입일: 09/26/18
193 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 220
