주요 콘텐츠로 건너뛰기
Asus G74SX-BBK7 RAM Replacement
필요한 것
  1. Asus G74SX-BBK7 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the large 13mm screw on the bottom of the laptop.
    • Take off the back panel.
  2. Asus G74SX-BBK7 RAM Replacement: 2 단계, 이미지 1/3 Asus G74SX-BBK7 RAM Replacement: 2 단계, 이미지 2/3 Asus G74SX-BBK7 RAM Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Locate the RAM near the center of the computer.
    • Push gently on the metal pins that are on both sides of the RAM sticks.
    • Before touching the RAM, discharge any built-up static by touching a metal surface or wearing an antistatic wrist strap.
  3. Asus G74SX-BBK7 RAM Replacement: 3 단계, 이미지 1/1
    • When you push on the pins, the RAM will pop up. Gently remove it from its socket.
    • Repeat the third and fourth step for the second stick of RAM, located behind the first stick.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Josiah Avery
회원 가입일: 04/15/15
131 평판
안내서 1개 작성함
Cal Poly, Team 5-10, Maness Spring 2015 Cal Poly, Team 5-10, Maness Spring 2015 회원
CPSU-MANESS-S15S5G10
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 18
전체 시간: 733
