주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus G74SX-BBK7 Trackpad Button Replacement
필요한 것
  1. Asus G74SX-BBK7 Trackpad Button Replacement, Optical Drive: 1 단계, 이미지 1개 중 1개
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the 13mm screw on the bottom of the laptop.
    • Take off the back panel.
  2. Asus G74SX-BBK7 Trackpad Button Replacement: 2 단계, 이미지 1개 중 1개
    • Now, unscrew and remove the 6mm Phillips #0 screw next to the optical drive.
  3. Asus G74SX-BBK7 Trackpad Button Replacement: 3 단계, 이미지 2개 중 1개 Asus G74SX-BBK7 Trackpad Button Replacement: 3 단계, 이미지 2개 중 2개
    • Lastly, use a plastic opening tool to remove the optical drive from its slot.
  4. Asus G74SX-BBK7 Trackpad Button Replacement, Trackpad Button: 4 단계, 이미지 1개 중 1개
    • Remove the two 6mm Phillips #0 screws that were previously covered by the optical drive using a Phillips #0 screwdriver.
  5. Asus G74SX-BBK7 Trackpad Button Replacement: 5 단계, 이미지 1개 중 1개
    • First, remove the five 10mm Phillips #0 screws from the back of the computer near the top.
    • Remove all eighteen 6mm Phillips #0 screws from the bottom of the computer.
    • Some of the screws are set very deeply in the back case - you will need a long and narrow screwdriver to remove them.
  6. Asus G74SX-BBK7 Trackpad Button Replacement: 6 단계, 이미지 2개 중 1개 Asus G74SX-BBK7 Trackpad Button Replacement: 6 단계, 이미지 2개 중 2개
    • Next, pry open back plastic cover using a metal spudger.
    • Unscrew the four 10mm Phillips #0 screws under the cover.
  7. Asus G74SX-BBK7 Trackpad Button Replacement: 7 단계, 이미지 3개 중 1개 Asus G74SX-BBK7 Trackpad Button Replacement: 7 단계, 이미지 3개 중 2개 Asus G74SX-BBK7 Trackpad Button Replacement: 7 단계, 이미지 3개 중 3개
    • Lay laptop opened and completely flat.
    • Using the metal spudger, slowly pry open the front main panel by going around each side.
    • Lift the top panel out, pulling the cable strips out of their sockets. These will be reattached later.
    • Be careful when lifting the top panel. There are cable strips attached to the motherboard that need to be removed.
  8. Asus G74SX-BBK7 Trackpad Button Replacement: 8 단계, 이미지 2개 중 1개 Asus G74SX-BBK7 Trackpad Button Replacement: 8 단계, 이미지 2개 중 2개
    • After separating the main panel and the motherboard, unscrew two 6mm Phillips #0 screws.
    • Remove the mouse button.
  9. Asus G74SX-BBK7 Trackpad Button Replacement: 9 단계, 이미지 3개 중 1개 Asus G74SX-BBK7 Trackpad Button Replacement: 9 단계, 이미지 3개 중 2개 Asus G74SX-BBK7 Trackpad Button Replacement: 9 단계, 이미지 3개 중 3개
    • To reconnect the motherboard and main panel, insert strips back to their corresponding location.
    • To do this, first remove the tape and open up the tab. Plug in the strip and and close the tab.
    • It may be helpful to have someone help you hold the main panel while you reconnect the strips.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ryan Lawrence
회원 가입일: 04/14/15
611 평판
안내서 5개를 작성함
Cal Poly, Team 5-10, Maness Spring 2015 Cal Poly, Team 5-10, Maness Spring 2015 회원
CPSU-MANESS-S15S5G10
4 회원들
안내서 6개를 작성함
1가이드 댓글
Where did you find the part?
websmiths - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 36
전체 시간: 5,107
