주요 콘텐츠로 건너뛰기
Asus G750JW-BBI7N05 Hard Drive Replacement
필요한 것
  1. Asus G750JW-BBI7N05 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/2 Asus G750JW-BBI7N05 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Lift up the rubber stopper on the backplate to expose one Phillips #00 screw. Unscrew it until it becomes loose.
    • This screw is permanently connected to the backplate and cannot be removed. Unscrewing it only allows you to remove the lower case from the laptop.
    • The backpate is the plastic plate on the underside of the laptop that covers some of its easily accessible internal components.
  5. Asus G750JW-BBI7N05 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Use an opening tool to pry up the backplate along its edges, then remove it.
    • You may need to apply some force when prying up the backplate.
    • Keep in mind: During reassembly, replace the backplate starting from the bottom.
  6. Asus G750JW-BBI7N05 Hard Drive Replacement: 6 단계, 이미지 1/2 Asus G750JW-BBI7N05 Hard Drive Replacement: 6 단계, 이미지 2/2
    • On the left metal hard drive casing, unscrew and remove the indicated three 4mm Phillips #00 screws.
    • The right hard drive casing is for optional secondary hard drives.
  7. Asus G750JW-BBI7N05 Hard Drive Replacement: 7 단계, 이미지 1/2 Asus G750JW-BBI7N05 Hard Drive Replacement: 7 단계, 이미지 2/2
    • Use the black tab as leverage to slide the metal hard drive casing all the way to the left.
    • Still holding the black tab, pull the hard drive casing up to remove it from the laptop.
  8. Asus G750JW-BBI7N05 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Unscrew and remove the four 4mm Phillips #00 screws around the metal casing. Each side has two screws.
    • Slide the hard drive out of its metal casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Siyuan Yan
회원 가입일: 10/05/17
131 평판
안내서 1개 작성함
Portland State University, Team S1-G1, Read Fall 2017 Portland State University, Team S1-G1, Read Fall 2017 회원
PSUN-READ-F17S1G1
2 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 20
전체 시간: 2,271
