주요 콘텐츠로 건너뛰기
Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement
필요한 것
  1. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Battery: 1 단계, 이미지 1/1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 2 단계, 이미지 1/1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 3 단계, 이미지 1/1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Left and Right Speaker Bar: 4 단계, 이미지 1/2 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Left and Right Speaker Bar: 4 단계, 이미지 2/2
    • Remove the rubber stoppers in the top left and right corners to expose two 9mm Phillips #00 screws. Unscrew and remove them.
    • Unscrew and remove the three 4mm Phillips #00 screws inside the battery compartment.
  5. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 5 단계, 이미지 1/1
    • Carefully turn the laptop right-side up.
    • Using an opening tool, pry the outer edges of the hinge cover up and away from the laptop.
    • The hinge cover, located at the back of the laptop, is the long plastic plate that covers the hinges and speakers.
  6. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 6 단계, 이미지 1/3 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 6 단계, 이미지 2/3 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 6 단계, 이미지 3/3
    • Without disconnecting the speaker cable, set the hinge cover upside-down.
    • Hold the speaker cable by its white connector, then pull to unplug it from the motherboard.
    • You may need to apply some force, as these connectors can be difficult to unplug.
  7. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 7 단계, 이미지 1/1
    • The speaker is attached to the hinge cover by four 3.5mm Phillips #00 screws. Unscrew and remove them.
  8. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 8 단계, 이미지 1/1
    • Lift the speaker to remove it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Stephanie Asling
회원 가입일: 10/05/17
424 평판
안내서 2개 작성하였습니다
Portland State University, Team S1-G1, Read Fall 2017 Portland State University, Team S1-G1, Read Fall 2017 회원
PSUN-READ-F17S1G1
2 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 735
