주요 콘텐츠로 건너뛰기
Asus G750JW-BBI7N05 RAM Replacement
필요한 것
  1. Asus G750JW-BBI7N05 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 RAM Replacement: 2 단계, 이미지 1/1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 RAM Replacement: 3 단계, 이미지 1/1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 RAM Replacement, RAM: 4 단계, 이미지 1/2 Asus G750JW-BBI7N05 RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Lift up the rubber stopper on the backplate to expose one Phillips screw. Unscrew it until it becomes loose.
    • This screw is permanently connected to the backplate and cannot be removed. Unscrewing it only allows you to remove the backplate from the laptop.
    • The backpate is the plastic plate on the underside of the laptop that covers some of its easily accessible internal components.
  5. Asus G750JW-BBI7N05 RAM Replacement: 5 단계, 이미지 1/1
    • Use an opening tool to pry up the backplate along its edges, then remove it.
    • You may need to apply some force when prying up the backplate.
    • Keep in mind: During reassembly, replace the backplate starting from the bottom.
  6. Asus G750JW-BBI7N05 RAM Replacement: 6 단계, 이미지 1/2 Asus G750JW-BBI7N05 RAM Replacement: 6 단계, 이미지 2/2
    • During the recycling process, this laptop lost some of its parts. In this step, its top two RAM modules are missing.
    • Remove each RAM module one at a time by sliding them downward out of their slots.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Stephanie Asling
회원 가입일: 10/05/17
424 평판
안내서 2개 작성하였습니다
Portland State University, Team S1-G1, Read Fall 2017 Portland State University, Team S1-G1, Read Fall 2017 회원
PSUN-READ-F17S1G1
2 회원들
안내서 3개 작성하였습니다
댓글 한 개
What about how to remove the other two internal RAM Modules?
Latiron London - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 761
