주요 콘텐츠로 건너뛰기
Asus G75VW-BHI7N07 Audio Jack Replacement
필요한 것
  1. Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: 1 단계, 이미지 1/3 Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: 1 단계, 이미지 2/3 Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: 1 단계, 이미지 3/3
    • Remove the 5 (9 mm screws) around the outside edges of the back cover with the PH1 Phillips-head screwdriver.
    • Lift off the back cover using the opening tool.
  2. Asus G75VW-BHI7N07 Audio Jack  Replacement: 2 단계, 이미지 1/3 Asus G75VW-BHI7N07 Audio Jack  Replacement: 2 단계, 이미지 2/3 Asus G75VW-BHI7N07 Audio Jack  Replacement: 2 단계, 이미지 3/3
    • Remove the 10 (9 mm) screws marked 'A' using the PH1 Phillips-head screwdriver.
    • Remove the battery by pressing the slide release button.
    • Remove 2 more (9 mm) 'A' marked screws within the battery compartment using the PH1 Phillips-head screwdriver.
  3. Asus G75VW-BHI7N07 Audio Jack  Replacement: 3 단계, 이미지 1/2 Asus G75VW-BHI7N07 Audio Jack  Replacement: 3 단계, 이미지 2/2
    • Remove the cover for the disc drive with the opening tool.
    • Remove the 6 (4 mm) 'B' marked screws with the PH1 Phillips-head screwdriver. (3 screws are in the battery compartment and 3 are under the disc drive cover)
  4. Asus G75VW-BHI7N07 Audio Jack  Replacement: 4 단계, 이미지 1/2 Asus G75VW-BHI7N07 Audio Jack  Replacement: 4 단계, 이미지 2/2
    • Pry open the keypad platform with the opening tool.
    • You will need to lift the keypad platform with your hands to get to the laptop's internal systems.
  5. Asus G75VW-BHI7N07 Audio Jack  Replacement: 5 단계, 이미지 1/3 Asus G75VW-BHI7N07 Audio Jack  Replacement: 5 단계, 이미지 2/3 Asus G75VW-BHI7N07 Audio Jack  Replacement: 5 단계, 이미지 3/3
    • Take out 1 (5mm) screw, using the J0 Phillips head screwdriver.
    • Use the opening tool to remove the audio-electrical board.
    • Lift out with your hands.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joy
회원 가입일: 09/08/17
437 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 6
전체 시간: 626
