소개
The Audio Jack can wear out over time or stop working completely. This guide will show you how to remove the Audio Jack on the side of the device.
필요한 것
Remove the 5 (9 mm screws) around the outside edges of the back cover with the PH1 Phillips-head screwdriver.
Lift off the back cover using the opening tool.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
