주요 콘텐츠로 건너뛰기
Asus G75VW-BHI7N07 Trackpad Buttons Replacement
필요한 것
  1. Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: 1 단계, 이미지 1/3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: 1 단계, 이미지 2/3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: 1 단계, 이미지 3/3
    • Remove the 5 (9 mm screws) around the outside edges of the back cover with the PH1 Phillips-head screwdriver.
    • Lift off the back cover using the opening tool.
  2. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 2 단계, 이미지 1/3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 2 단계, 이미지 2/3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 2 단계, 이미지 3/3
    • Remove the 10 (9 mm) screws marked 'A' using the PH1 Phillips-head screwdriver.
    • Remove the battery by pressing the slide release button.
    • Remove 2 more (9 mm) 'A' marked screws within the battery compartment using the PH1 Phillips-head screwdriver.
  3. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 3 단계, 이미지 1/2 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 3 단계, 이미지 2/2
    • Remove the cover for the disc drive with the opening tool.
    • Remove the 6 (4 mm) 'B' marked screws with the PH1 Phillips-head screwdriver. (3 screws are in the battery compartment and 3 are under the disc drive cover)
  4. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 4 단계, 이미지 1/2 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 4 단계, 이미지 2/2
    • Take off the henge cover using the opening tool.
    • Remove the 2 black outside edge (9 mm) screws with the J0 Phillips screwdriver.
  5. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 5 단계, 이미지 1/3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 5 단계, 이미지 2/3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 5 단계, 이미지 3/3
    • Pry open the keypad platform with the opening tool.
    • You will need to lift the keypad platform with your hands.
    • Remove all electrical connections using your hands.
  6. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 6 단계, 이미지 1/2 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 6 단계, 이미지 2/2
    • Take the 2 (3 mm) screws out of the trackpad using the PH1 Phillips screwdriver.
    • Remove the trackpad buttons using your hands.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tai Dean
회원 가입일: 09/08/17
173 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 12
전체 시간: 1,301
