주요 콘텐츠로 건너뛰기
Asus GL551JW-AH71 Fan Replacement
필요한 것
  1. Asus GL551JW-AH71 Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Fan Replacement: 2 단계, 이미지 1/2 Asus GL551JW-AH71 Fan Replacement: 2 단계, 이미지 2/2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Fan Replacement: 3 단계, 이미지 1/2 Asus GL551JW-AH71 Fan Replacement: 3 단계, 이미지 2/2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Fan Replacement, Optical Drive: 4 단계, 이미지 1/2 Asus GL551JW-AH71 Fan Replacement, Optical Drive: 4 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
  5. Asus GL551JW-AH71 Fan Replacement: 5 단계, 이미지 1/3 Asus GL551JW-AH71 Fan Replacement: 5 단계, 이미지 2/3 Asus GL551JW-AH71 Fan Replacement: 5 단계, 이미지 3/3
    • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
  6. Asus GL551JW-AH71 Fan Replacement: 6 단계, 이미지 1/2 Asus GL551JW-AH71 Fan Replacement: 6 단계, 이미지 2/2
    • Gently grasp the optical drive assembly and slide it out of the laptop body.
  7. Asus GL551JW-AH71 Fan Replacement, Upper Assembly: 7 단계, 이미지 1/2 Asus GL551JW-AH71 Fan Replacement, Upper Assembly: 7 단계, 이미지 2/2
    • Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
  8. Asus GL551JW-AH71 Fan Replacement: 8 단계, 이미지 1/2 Asus GL551JW-AH71 Fan Replacement: 8 단계, 이미지 2/2
    • Carefully remove the access panel.
  9. Asus GL551JW-AH71 Fan Replacement: 9 단계, 이미지 1/2 Asus GL551JW-AH71 Fan Replacement: 9 단계, 이미지 2/2
    • Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
  10. Asus GL551JW-AH71 Fan Replacement: 10 단계, 이미지 1/1
    • Turn the laptop over and open the screen.
  11. Asus GL551JW-AH71 Fan Replacement: 11 단계, 이미지 1/3 Asus GL551JW-AH71 Fan Replacement: 11 단계, 이미지 2/3 Asus GL551JW-AH71 Fan Replacement: 11 단계, 이미지 3/3
    • Gently pry open the case with an iFixit opening tool.
    • The upper and lower assembly are connected with a display cable that will be removed in the next step. Do not pull the parts apart more than a few inches.
  12. Asus GL551JW-AH71 Fan Replacement: 12 단계, 이미지 1/3 Asus GL551JW-AH71 Fan Replacement: 12 단계, 이미지 2/3 Asus GL551JW-AH71 Fan Replacement: 12 단계, 이미지 3/3
    • Flip the laptop on the right side while still holding the upper and lower assemblies close together.
    • Unplug the display connector from the motherboard.
    • Remove the upper assembly.
  13. Asus GL551JW-AH71 Fan Replacement, Fan: 13 단계, 이미지 1/1
    • Place the separated motherboard keyboard side down.
  14. Asus GL551JW-AH71 Fan Replacement: 14 단계, 이미지 1/3 Asus GL551JW-AH71 Fan Replacement: 14 단계, 이미지 2/3 Asus GL551JW-AH71 Fan Replacement: 14 단계, 이미지 3/3
    • Unplug the fan connector cable from the motherboard with an iFixit opening tool.
  15. Asus GL551JW-AH71 Fan Replacement: 15 단계, 이미지 1/2 Asus GL551JW-AH71 Fan Replacement: 15 단계, 이미지 2/2
    • With a Phillips #00 screwdriver, remove the three 5mm screws that hold the fan in place.
  16. Asus GL551JW-AH71 Fan Replacement: 16 단계, 이미지 1/2 Asus GL551JW-AH71 Fan Replacement: 16 단계, 이미지 2/2
    • Gently remove the fan from the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
William Kelley
회원 가입일: 03/20/19
1,035 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 UMass Dartmouth, Team S8-G3, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S8G3
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 34
전체 시간: 1,526
