소개
This guide outlines how to replace the fan in the Asus GL551JW-AH71.
필요한 것
Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
