주요 콘텐츠로 건너뛰기
Asus GL551JW-AH71 Hard Drive Replacement
필요한 것
  1. Asus GL551JW-AH71 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Hard Drive Replacement: 2 단계, 이미지 1/2 Asus GL551JW-AH71 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Hard Drive Replacement: 3 단계, 이미지 1/2 Asus GL551JW-AH71 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/2 Asus GL551JW-AH71 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the two 16 mm screws on the access panel.
  5. Asus GL551JW-AH71 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Remove the access panel by lifting it up.
  6. Asus GL551JW-AH71 Hard Drive Replacement: 6 단계, 이미지 1/2 Asus GL551JW-AH71 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Using the Phillips #000 screwdriver, remove the four screws holding the hard drive in place.
    • The pictures in this step do not contain a a hard drive. The location where the hard drive would be located is indicated by the orange rectangle.
  7. Asus GL551JW-AH71 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Pull out hard drive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
William Kelley
회원 가입일: 03/20/19
1,035 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 UMass Dartmouth, Team S8-G3, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S8G3
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 304
