주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus GTX 750 GPU Fan Replacement
필요한 것
    1. Asus GTX 750 GPU Fan Replacement, Asus GTX 750 GPU Fan: 1 단계, 이미지 3개 중 1개 Asus GTX 750 GPU Fan Replacement, Asus GTX 750 GPU Fan: 1 단계, 이미지 3개 중 2개 Asus GTX 750 GPU Fan Replacement, Asus GTX 750 GPU Fan: 1 단계, 이미지 3개 중 3개
      • Before beginning the repair process, make sure that your designated workspace is decluttered and clean.
      • The smaller parts of the device may be at risk of being lost or misplaced if the workspace is not decluttered.
      • Orient the case so that the power button is aligned with the rightmost corner of the device.
      • Next, push the ridge-line of the top panel away.
      • Then, slide the case away and expose the inside of the product.
      • Continue this process to lift off the side panel that was previously facing you.
      댓글 쓰기
    2. Asus GTX 750 GPU Fan Replacement: 2 단계, 이미지 2개 중 1개 Asus GTX 750 GPU Fan Replacement: 2 단계, 이미지 2개 중 2개
      • Next, disconnect the GPU cable with your thumb and forefinger. This will partially unhook the fan from the motherboard.
      • If working with any model of this device other than the ASUS GTX 750, pull the cable away from the motherboard. If not, this note may be disregarded.
      • On the PCIe slot of the graphics card, there is a release mechanism. Push on this mechanism carefully and gently.
      • After pushing it down, the device will click and signify correct and complete separation from the motherboard.
      • Use caution, and do not touch the motherboard with your bare hands, as it may cause a short in the system.
      댓글 쓰기
    3. Asus GTX 750 GPU Fan Replacement: 3 단계, 이미지 2개 중 1개 Asus GTX 750 GPU Fan Replacement: 3 단계, 이미지 2개 중 2개
      • Finally, with the GPU unit exposed, disconnect the 4-pin fan power and speed control cable from the circuit board.
      • Refer to the photographs on the left if needed.
      댓글 쓰기
    4. Asus GTX 750 GPU Fan Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Phillips #00 Screwdriver
      $5.49
      • Remove the four smallest screws that are holding the fan shroud in place.
      • Do so by using a (Phillips #00) screwdriver between the fan blades and corresponding supporting bracket.
      댓글 쓰기
    5. Asus GTX 750 GPU Fan Replacement: 5 단계, 이미지 2개 중 1개 Asus GTX 750 GPU Fan Replacement: 5 단계, 이미지 2개 중 2개
      • Locate the two clips on either side of the fan shroud.
      • Then, pull the clips slightly to the side and release the fan shroud from the heatsink.
      • Finally, pull the fan shroud vertically to remove from the device and allow for an unobstructed review and repair.
      댓글 쓰기
    6. Asus GTX 750 GPU Fan Replacement: 6 단계, 이미지 1개 중 1개
      • At this stage, you may reverse the disassembly process to reassemble the fan shroud and place it within the unit.
      댓글 쓰기
결론
In order to reassemble this device, follow the provided instructions in the reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Zhiming Lin
회원 가입일: 09/26/22
178 평판
안내서 1개를 작성함
York University, Team A-4, Morris Fall 2022 York University, Team A-4, Morris Fall 2022 회원
YORK-MORRIS-F22SAG4
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 50
전체 시간: 2,345
