소개
Charging port pieces inside of the laptop may get damaged and not allow it to charge. This guide will help you replace the charging port inside the ASUS K50IJ.
필요한 것
Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
Using the PH1 screwdriver remove the two .75 mm screws from the hinge side of the laptop.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Cool really nice guide. If I could rate I would give it a 5 but I got one question. How tf do I put it back together now?
