주요 콘텐츠로 건너뛰기
Asus K52JC Laptop Hard Drive Replacement
필요한 것
  1. Asus K52JC Laptop Hard Drive Replacement, Power off and return the device: 1 단계, 이미지 1/1
    • First, turn off your laptop, then disconnect the power supply. Unplug any peripheral devices connected to your laptop.
    • Next, remove the battery from the laptop.
    • In the picture, the battery is not installed.
  2. Asus K52JC Laptop Hard Drive Replacement, Remove the screws and open the cover: 2 단계, 이미지 1/2 Asus K52JC Laptop Hard Drive Replacement, Remove the screws and open the cover: 2 단계, 이미지 2/2
    • Next, remove the 4 Phillips screws from the service door cover (circled in red).
    • In this photo, the screws have already been removed.
  3. Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from it's location: 3 단계, 이미지 1/2 Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from it's location: 3 단계, 이미지 2/2
    • Remove the 4 screws circled in red in the photo.
    • Once the screws are removed, slide the hard drive to the right, with the help of the tab.
  4. Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from its metal support bracket: 4 단계, 이미지 1/3 Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from its metal support bracket: 4 단계, 이미지 2/3 Asus K52JC Laptop Hard Drive Replacement, Remove the hard drive from its metal support bracket: 4 단계, 이미지 3/3
    • Remove the 4 screws located on the side of the support.
    • Then, remove the hard drive form its metallic support.
    • Finally, replace de hard drive with a new one or an SSD.
결론
To reassemble your device, follow these steps in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Brendan
회원 가입일: 09/24/16
51,566 평판
안내서 3개 작성하였습니다
댓글 3개
why do you do this?
Carl Jefferson - 답글
You can do this to replace a faulty hard-drive or replace it by a SSD to get better performance. So I did this to replace mine by a new one and I wrote this guide for other people who search how to do it. As you can see, very easy to do.
Brendan -
Amazing tutorial, thanks :)
Jérémy Martin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 23
전체 시간: 1,503
