주요 콘텐츠로 건너뛰기
Asus K53E-BBR3 Hard Drive Replacement
필요한 것
  1. Asus K53E-BBR3 Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 Asus K53E-BBR3 Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 Asus K53E-BBR3 Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Hard Drive Replacement, Back Panel: 2 단계, 이미지 1/1
    • Unscrew two 5mm Phillips #1 screws.
  3. Asus K53E-BBR3 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Pull down and lift up on the back panel to remove it.
  4. Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/3 Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/3 Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3/3
    • Unscrew the four 5mm Phillips #1 screws.
    • Lift the hard drive out of the computer.
  5. Asus K53E-BBR3 Hard Drive Replacement: 5 단계, 이미지 1/2 Asus K53E-BBR3 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Unscrew the screws on the hard drive case.
    • Two 3mm Phillips #1 screws are located on one edge of the case.
    • The last two 3mm #1 Phillips screws are located on the opposite side of the case.
    • After you unscrew all four screws, the metal cage will fall off, leaving you with the hard drive.
결론
Jacob O'Donnell
회원 가입일: 10/17/16
323 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-1, Catania Fall 2016 UMass Dartmouth, Team 1-1, Catania Fall 2016 회원
UMASSD-CATANIA-F16S1G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 1,745
