소개
If your laptop is failing to boot properly, your motherboard may be to blame. Replacing your motherboard using this guide will ensure that your laptop operates successfully.
필요한 것
Turn off the computer and disconnect the charging cable from the laptop.
Push the two locking mechanisms at the top of the laptop outward and pull the battery away from the laptop.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
