주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus K53E-BBR7 Optical Drive Replacement
필요한 것
  1. Asus K53E-BBR7 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 3개 중 1개 Asus K53E-BBR7 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 3개 중 2개 Asus K53E-BBR7 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 3개 중 3개
    • Push the two locking mechanisms at the top of your laptop away from each other.
    • Pull the battery away from your laptop using your hands.
    • The battery of this laptop is missing.
  2. Asus K53E-BBR7 Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two black 7.0 mm Phillips #0 screws from the back cover of your laptop.
  3. Asus K53E-BBR7 Optical Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the back panel by sliding the panel downwards with your hands.
  4. Asus K53E-BBR7 Optical Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Use your Phillips #0 screwdriver to remove the four 7.0 mm Phillips #0 screws surrounding the hard drive.
    • Use your hands to slowly pull the hard drive out of your laptop.
    • The hard drive of this laptop is missing.
  5. Asus K53E-BBR7 Optical Drive Replacement: 5 단계, 이미지 2개 중 1개 Asus K53E-BBR7 Optical Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Using your Phillips #0 screwdriver, remove the following seventeen screws from your laptop:
    • Sixteen black 7.0 mm Phillips #0 screws
    • One silver 4.0 mm Phillips #0 screw
  6. Asus K53E-BBR7 Optical Drive Replacement: 6 단계, 이미지 3개 중 1개 Asus K53E-BBR7 Optical Drive Replacement: 6 단계, 이미지 3개 중 2개 Asus K53E-BBR7 Optical Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Flip the laptop over and open the lid to reveal the keyboard.
    • Insert the blue prying tool into each of the five tabs located at the top of the keyboard, pulling upwards on the keyboard to separate it from the palm rest.
    • Once the top of the keyboard has been separated from the device, slowly begin pulling the keyboard away from the laptop using your hands.
    • A silver ribbon cable is connected to the keyboard and the palm rest of the laptop. Removing the keyboard quickly may tear the silver ribbon cable, causing harm to your device.
  7. Asus K53E-BBR7 Optical Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Using your fingers, gently disconnect the silver ribbon cable from the laptop by pulling the cable out of the slot and to the right.
    • When separating the ribbon cable from the laptop, be gentle. Improperly removing the ribbon cable from the device can damage the laptop.
  8. Asus K53E-BBR7 Optical Drive Replacement: 8 단계, 이미지 2개 중 1개 Asus K53E-BBR7 Optical Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the single silver 6.0 mm Phillips #0 screw that connects the optical drive to the palm rest.
  9. Asus K53E-BBR7 Optical Drive Replacement: 9 단계, 이미지 2개 중 1개 Asus K53E-BBR7 Optical Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the optical drive from the laptop by pulling it to the right with your hands.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Christina Nelson
회원 가입일: 10/18/16
289 평판
안내서 1개를 작성함
UW Tacoma, Team 1-3, Rose Fall 2016 UW Tacoma, Team 1-3, Rose Fall 2016 회원
UWT-ROSE-F16S1G3
4 회원들
안내서 4개를 작성함
1가이드 댓글
Most of these steps are unnecessary to get to the dvd-drive. The keyboard clicks loose without removing these screws too, so only steps 7, 8 and 9 are needed.
Nick - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 24
전체 시간: 3,047
