주요 콘텐츠로 건너뛰기
Asus K53S -X156V Thermal Paste Replacement
필요한 것
  1. Asus K53S -X156V Thermal Paste Replacement, removing battery: 1 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, removing battery: 1 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, removing battery: 1 단계, 이미지 3/3
    • remove battery by sliding the two release buttons to the right position.
    • slide the battery away from the laptop
  2. Asus K53S -X156V Thermal Paste Replacement, removing plastic plate RAM/HDD: 2 단계, 이미지 1/2 Asus K53S -X156V Thermal Paste Replacement, removing plastic plate RAM/HDD: 2 단계, 이미지 2/2
    • remove the 2 screws holding the plastic plate , underneath is the RAM/ WiFi and HDD
    • the 2 screws are marked in red. afterwarts slide it away from the laptop
    • keep track of all the screws and parts. make a map or a plan.
  3. Asus K53S -X156V Thermal Paste Replacement, removing RAM: 3 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, removing RAM: 3 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, removing RAM: 3 단계, 이미지 3/3
    • click the ram module out of there sockets.
    • push the metal clips away from the module.
  4. Asus K53S -X156V Thermal Paste Replacement, Remove wifi module: 4 단계, 이미지 1/2 Asus K53S -X156V Thermal Paste Replacement, Remove wifi module: 4 단계, 이미지 2/2
    • remove the black and white wire.
    • remove the screw.
  5. Asus K53S -X156V Thermal Paste Replacement, removing hard disk: 5 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, removing hard disk: 5 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, removing hard disk: 5 단계, 이미지 3/3
    • remove the 4 screws holding the metal frame , holding the hdd to it's place.
    • slide the frame and hard disk away from the case.
  6. Asus K53S -X156V Thermal Paste Replacement, removing keyboard: 6 단계, 이미지 1/2 Asus K53S -X156V Thermal Paste Replacement, removing keyboard: 6 단계, 이미지 2/2
    • click the keyboard loose . There are 5 clips to remove
  7. Asus K53S -X156V Thermal Paste Replacement, keyboard second part: 7 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, keyboard second part: 7 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, keyboard second part: 7 단계, 이미지 3/3
    • be carefull with the flat cable from the keyboard.
    • use a spudger to click the connector lid loose.
    • i used the tip of a screwdriver.. but i know what i am doing.. if you are use to work on laptops you can use a screwdriver, if not use a plastic spudger.
  8. Asus K53S -X156V Thermal Paste Replacement, remove DVD bay: 8 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, remove DVD bay: 8 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, remove DVD bay: 8 단계, 이미지 3/3
    • remove the screw hidden under the keyboard.
    • slide the dvd bay out.
  9. Asus K53S -X156V Thermal Paste Replacement, removing flat cables: 9 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, removing flat cables: 9 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, removing flat cables: 9 단계, 이미지 3/3
    • remove the flat thin cables from there sockets.
    • use a spudger , click the lid upwards and slide the flat cable out.
  10. Asus K53S -X156V Thermal Paste Replacement: 10 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement: 10 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement: 10 단계, 이미지 3/3
    • remove the 6 screws ( m2x6) holding the metal plate to the case.
  11. Asus K53S -X156V Thermal Paste Replacement, remove screws on the bottom plate: 11 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, remove screws on the bottom plate: 11 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, remove screws on the bottom plate: 11 단계, 이미지 3/3
    • remove screws as shown in pictures.
  12. Asus K53S -X156V Thermal Paste Replacement, remove screws bottom plate: 12 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, remove screws bottom plate: 12 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, remove screws bottom plate: 12 단계, 이미지 3/3
  13. Asus K53S -X156V Thermal Paste Replacement, removing case: 13 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, removing case: 13 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, removing case: 13 단계, 이미지 3/3
    • slide an isesamo opening tool between the two plates. you will here clicks
  14. Asus K53S -X156V Thermal Paste Replacement, reveal MAIN PCB: 14 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, reveal MAIN PCB: 14 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, reveal MAIN PCB: 14 단계, 이미지 3/3
    • remove upper plate , revealing the main PCB.
  15. Asus K53S -X156V Thermal Paste Replacement, removing cable to usb module: 15 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, removing cable to usb module: 15 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, removing cable to usb module: 15 단계, 이미지 3/3
    • remove the flat cable of the USB module , use a spudger to lift up the lid of the connector.
    • gently slide out the flat cable
    • when removing the cable, be carefull they used a lot of adhessive to paste the cable to the plastic case.
  16. Asus K53S -X156V Thermal Paste Replacement, removing LCD cable: 16 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, removing LCD cable: 16 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, removing LCD cable: 16 단계, 이미지 3/3
    • use the tip of a spudger or a tiny flathead screwdriver to push out the LCD cable from connector.
    • be very very very carefull , if you tear tis cable or damage it , you will have to buy a new one.
    • first lift the cable metal connector upwards ( push it out) , very gently, then the other side untill you can remove the cable.
  17. Asus K53S -X156V Thermal Paste Replacement, remove audio cable: 17 단계, 이미지 1/2 Asus K53S -X156V Thermal Paste Replacement, remove audio cable: 17 단계, 이미지 2/2
    • use IC extractor pliers to remove the cable away from is socket.
  18. Asus K53S -X156V Thermal Paste Replacement, remove screws main board: 18 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, remove screws main board: 18 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, remove screws main board: 18 단계, 이미지 3/3
    • remove the 4 screws holding the main pcb ..
  19. Asus K53S -X156V Thermal Paste Replacement, removing last screw.: 19 단계, 이미지 1/1
    • remove screw holding the fan tot the laptop.
  20. Asus K53S -X156V Thermal Paste Replacement, removing main board: 20 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, removing main board: 20 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, removing main board: 20 단계, 이미지 3/3
    • lift the main board or motherboard up on the right side and slide it out.
  21. Asus K53S -X156V Thermal Paste Replacement, FAN: 21 단계, 이미지 1/2 Asus K53S -X156V Thermal Paste Replacement, FAN: 21 단계, 이미지 2/2
    • release the fan from the main board by removing the connector with an IC extractor pliers.
  22. Asus K53S -X156V Thermal Paste Replacement: 22 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement: 22 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement: 22 단계, 이미지 3/3
    • loosen up the screws from the cooling pads on the CPU and GPU.
    • You will have to tear the warranty sticker. it is a sticker in 3 parts.
  23. Asus K53S -X156V Thermal Paste Replacement, removing fan and cooling pads: 23 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, removing fan and cooling pads: 23 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, removing fan and cooling pads: 23 단계, 이미지 3/3
    • remove the fan and cooling pads.
    • you will see the old thermal paste.
  24. Asus K53S -X156V Thermal Paste Replacement, removing thermal paste from pads.: 24 단계, 이미지 1/2 Asus K53S -X156V Thermal Paste Replacement, removing thermal paste from pads.: 24 단계, 이미지 2/2
    • clean the cooling pads with an very sharp knife. or spudger..
    • wear gloves, cause the thermal paste is very toxic.
    • also this is a good time to blow out the fan with compressed air.
  25. Asus K53S -X156V Thermal Paste Replacement, removing CPU and cleaning: 25 단계, 이미지 1/3 Asus K53S -X156V Thermal Paste Replacement, removing CPU and cleaning: 25 단계, 이미지 2/3 Asus K53S -X156V Thermal Paste Replacement, removing CPU and cleaning: 25 단계, 이미지 3/3
    • remove the old thermal paste from the processors , be very carefull. and use some artic silver liquid to clean them. and easely remove the thermal paste.
    • you can remove the CPU by using a flathead screwdriver , the socket will move and you can pull the CPU out , maybe a good time to upgrade the CPU.
  26. Asus K53S -X156V Thermal Paste Replacement: 26 단계, 이미지 1/1
    • unfortunately i don't have a picture when i added some new thermal paste. But if you do: one drop on each processor is enough.
    • Check out the thermal paste guide for more information on how to apply thermal paste.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Kevin D
회원 가입일: 05/02/14
7,294 평판
안내서 21개 작성하였습니다
댓글 4개
You dont have to disassembly whole computer, just remove back cover, 4 screws from cpu, 2 screws from gpu and 2 screws from fan..
Aleksi Kinnunen - 답글
Hi Aleksi,
Yes we know, but we took the hole laptop apart to show how to replace, renew other parts as well.
Kevin D - 답글
Ciao, io ho fatto tutto perfettamente in modo identico alla spiegazione (anche perché non è complicato). può essere la cpu?
Irene Montanari - 답글
Which themal paste good . Please give amazon purchase link
Vinayak Patil - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 51
전체 시간: 5,189
