필요한 것
remove battery by sliding the two release buttons to the right position.
slide the battery away from the laptop
remove the 2 screws holding the plastic plate , underneath is the RAM/ WiFi and HDD
the 2 screws are marked in red. afterwarts slide it away from the laptop
click the ram module out of there sockets.
push the metal clips away from the module.
remove the 4 screws holding the metal frame , holding the hdd to it's place.
slide the frame and hard disk away from the case.
be carefull with the flat cable from the keyboard.
use a spudger to click the connector lid loose.
i used the tip of a screwdriver.. but i know what i am doing.. if you are use to work on laptops you can use a screwdriver, if not use a plastic spudger.
remove the flat thin cables from there sockets.
use a spudger , click the lid upwards and slide the flat cable out.
remove the flat cable of the USB module , use a spudger to lift up the lid of the connector.
gently slide out the flat cable
use the tip of a spudger or a tiny flathead screwdriver to push out the LCD cable from connector.
be very very very carefull , if you tear tis cable or damage it , you will have to buy a new one.
first lift the cable metal connector upwards ( push it out) , very gently, then the other side untill you can remove the cable.
lift the main board or motherboard up on the right side and slide it out.
remove the fan and cooling pads.
you will see the old thermal paste.
clean the cooling pads with an very sharp knife. or spudger..
wear gloves, cause the thermal paste is very toxic.
also this is a good time to blow out the fan with compressed air.
remove the old thermal paste from the processors , be very carefull. and use some artic silver liquid to clean them. and easely remove the thermal paste.
you can remove the CPU by using a flathead screwdriver , the socket will move and you can pull the CPU out , maybe a good time to upgrade the CPU.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 4개
You dont have to disassembly whole computer, just remove back cover, 4 screws from cpu, 2 screws from gpu and 2 screws from fan..
Ciao, io ho fatto tutto perfettamente in modo identico alla spiegazione (anche perché non è complicato). può essere la cpu?
Which themal paste good . Please give amazon purchase link
