소개
If your Asus K55VD is having problems reading DVDs, not playing audio or videos properly, or DVD programs won't install properly then it may be experiencing a faulty optical disk drive which needs to be replaced.
필요한 것
1 단계 Battery
주의: 1 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
Flip the device over to its back cover.
Use the switches to release the battery from its adapter.
Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
After removing the screws, remove the smaller cover.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
LOL if you want to get out drive, open dvd drive, turn laptop off, remove screw cover, unscrew, pull the drive out, done :D This is stupidly overcomplicated and unnecessary.
