주요 콘텐츠로 건너뛰기
Asus K55VD DVD Player Replacement
필요한 것
  1. 주의: 1 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
    • Power off the device completely
    • Flip the device over to its back cover.
    • Use the switches to release the battery from its adapter.
  2. Asus K55VD DVD Player Replacement, Hard Drive: 2 단계, 이미지 1/2 Asus K55VD DVD Player Replacement, Hard Drive: 2 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
    • After removing the screws, remove the smaller cover.
  3. Asus K55VD DVD Player Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the 1.5 mm screws that hold down the hard drive.
    The bottom left screw does not hold down the drive bay. Unsrew that screw in step 5.
    Daniel - 답글
  4. Asus K55VD DVD Player Replacement: 4 단계, 이미지 1/2 Asus K55VD DVD Player Replacement: 4 단계, 이미지 2/2
    • Remove the hard drive from the slot.
    • Remove the hard drive from its shell.
  5. Asus K55VD DVD Player Replacement, Optical Disk Drive: 5 단계, 이미지 1/1
    • Using the the Philips #0 Screwdriver remove highlighted screws.
  6. Asus K55VD DVD Player Replacement: 6 단계, 이미지 1/1
    • Lift plastic cover with tweezers.
    • Remove screw.
  7. Asus K55VD DVD Player Replacement: 7 단계, 이미지 1/1
    • Lift keyboard panel with plastic pry tool to remove.
  8. Asus K55VD DVD Player Replacement: 8 단계, 이미지 1/2 Asus K55VD DVD Player Replacement: 8 단계, 이미지 2/2
    • Unhook all ribbons to remove keyboard panel completely.
  9. Asus K55VD DVD Player Replacement: 9 단계, 이미지 1/2 Asus K55VD DVD Player Replacement: 9 단계, 이미지 2/2
    • Slide the DVD Player outward.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Hector Morales
회원 가입일: 09/21/18
155 평판
안내서 1개 작성함
댓글 한 개
LOL if you want to get out drive, open dvd drive, turn laptop off, remove screw cover, unscrew, pull the drive out, done :D This is stupidly overcomplicated and unnecessary.
Luke Malatinsky - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 1,154
