주요 콘텐츠로 건너뛰기
Asus K55VD Fan Replacement
필요한 것
  1. 주의: 1 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
    • Power off the device completely
    • Flip the device over to its back cover.
    • Use the switches to release the battery from its adapter.
  2. Asus K55VD Fan Replacement, Hard Drive: 2 단계, 이미지 1/2 Asus K55VD Fan Replacement, Hard Drive: 2 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
    • After removing the screws, remove the smaller cover.
  3. Asus K55VD Fan Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the 1.5 mm screws that hold down the hard drive.
  4. Asus K55VD Fan Replacement: 4 단계, 이미지 1/2 Asus K55VD Fan Replacement: 4 단계, 이미지 2/2
    • Remove the hard drive from the slot.
    • Remove the hard drive from its shell.
  5. Asus K55VD Fan Replacement, Fan: 5 단계, 이미지 1/3 Asus K55VD Fan Replacement, Fan: 5 단계, 이미지 2/3 Asus K55VD Fan Replacement, Fan: 5 단계, 이미지 3/3
    • Remove all 12 screws from the bottom cover with a Phillips #0 screwdriver.
    • The four screws nearest the display hinges are longer.
    • The single screw in the middle of the bottom cover is shorter than the rest.
  6. Asus K55VD Fan Replacement: 6 단계, 이미지 1/3 Asus K55VD Fan Replacement: 6 단계, 이미지 2/3 Asus K55VD Fan Replacement: 6 단계, 이미지 3/3
    • After the screws are removed, Orientate the device so that the keyboard is shown.
    • Using the Plastic Pry tool separate the keyboard panel from the rest of the laptop.
  7. Asus K55VD Fan Replacement: 7 단계, 이미지 1/2 Asus K55VD Fan Replacement: 7 단계, 이미지 2/2
    • Before the keyboard panel can be fully removed, detach the three cords that connect to the keyboard.
    • Lift up on the black tab and the cord will fall out.
  8. Asus K55VD Fan Replacement: 8 단계, 이미지 1/3 Asus K55VD Fan Replacement: 8 단계, 이미지 2/3 Asus K55VD Fan Replacement: 8 단계, 이미지 3/3
    • Remove the optical dive by sliding it outward.
  9. Asus K55VD Fan Replacement: 9 단계, 이미지 1/3 Asus K55VD Fan Replacement: 9 단계, 이미지 2/3 Asus K55VD Fan Replacement: 9 단계, 이미지 3/3
    • Now remove the two wires shown by pulling away from the motherboard.
  10. Asus K55VD Fan Replacement: 10 단계, 이미지 1/3 Asus K55VD Fan Replacement: 10 단계, 이미지 2/3 Asus K55VD Fan Replacement: 10 단계, 이미지 3/3
    • Remove the three screws holding the motherboard and fan in place using the Phillips #0 bit.
    • The top left screw shown in the first picture is easily broken
  11. Asus K55VD Fan Replacement: 11 단계, 이미지 1/3 Asus K55VD Fan Replacement: 11 단계, 이미지 2/3 Asus K55VD Fan Replacement: 11 단계, 이미지 3/3
    • lift up on the entire motherboard and unplug the bottom wires connected to the fan.
  12. Asus K55VD Fan Replacement: 12 단계, 이미지 1/2 Asus K55VD Fan Replacement: 12 단계, 이미지 2/2
    • After all cords have been removed, the fan can be removed as well.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Charter Mitchell
회원 가입일: 09/21/18
335 평판
안내서 1개 작성함
댓글 2개
At step 5, you should also unscrew the bottom silver screw and unplug the wifi antennas.
https://i.imgur.com/vRrlRkv.png
Daniel - 답글
At step 3, the bottom left screw does not hold down the drive bay. Unsrew that screw in step 5.
Daniel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 40
전체 시간: 2,688
