소개
When the RAM is replaced, you will have the ability to easily access frequently used files, boost the speed of your laptop and eliminate error messages. Before you begin, you must ensure that the device is completely powered off and the battery is removed.
필요한 것
1 단계 Battery
주의: 1 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
Flip the device over to its back cover.
Use the switches to release the battery from its adapter.
다른 2명이 해당 안내서를 완성하였습니다.
